    [Plugin] LordOfTheToolbars - v4.2a - 21 Oct 26
    548 Posts 101 Posters 601.0k Views 99 Watching
    • LinearGraphsL
      LinearGraphs
      I used to only use external monitors, but now im using the laptop screen. Tried all scale settings, no dice.
      • fredo6F
        fredo6
        This is an issue with SU2017, which as far as I remember does not support well external monitors with different resolutions as the main computer screen.
        Could you go to Window > LibFredo6 Settings... > Default Parameters
        At the top of the dialog box, check the first line and set the factor to 1.5
        No guarantee it works, but worth trying.
        LinearGraphsL 2 Replies Last reply ๐Ÿ˜ฟ
        • jujuJ
          juju @juju
          juju said:
          @fredo6 Thank you for the effort you put into your extensions and maintaining them, it is appreciated.
          The Muzwalls loading error seems to be resolved, that error message no longer pops up. Unfortunately the custom toolbars with the MuzWalls items doesn't work, buttons greyed out while the actual MuzWalls toolbars are fine and functional.
          The toolbar editing problem, where items are not added once the toolbar was checked to appear on screen, still persists. It doesn't update any custom toolbar additions or omissions once the toolbar was selected to appear on screen. The only work-around is to delete the toolbar and recreate it from fresh.
          @fredo6 Any ideas on this yet?
          • fredo6F
            fredo6
            Did you solve the problem of size of the Vignette Stripe?
            For Muzwalls, I think this is due to the late loading of the plugin. So, LOTT cannot catch them at startup.
            For custom toolbars, I can check, but I think you have to restart Sketchup to see the changes.
            jujuJ 1 Reply Last reply
            • LinearGraphsL
              LinearGraphs @fredo6
              @fredo6
              Unfortunately, no. No dice. Still clipped.
              • LinearGraphsL
                @fredo6
                Is there no way to reset it? Mind you, this is happening on the laptop display with no external monitors connected.
                • jujuJ
                  juju @fredo6
                  Is there no load delay option that can be done? Or perhaps advise for MuzWalls authors how to get it to load faster and checking of licensing? There are other extensions that also have to load and check licensing that do seem to load fine.
                  I've tried restarting inbetween, it doesn't make a difference, changes do not reflect once the custom toolbar was actualised (ticked) to show on screen, even if you switch it off and switch it back on later.
                  • fredo6F
                    fredo6
                    Custom toolbars cannot be updated once on screen. This is because toolbars in Sketchup are not editable. I think LOTT can just add new icons.
                    Normally, at next restart, the custom toolbars should show as designed.
                    For Muzwalls, I have to check what is the real issue.
                    • 24
                    • 25
                    • 26
                    • 27
                    • 28
                    • 28 / 28
