Welds not saving in sketch up pro
I've just started using the weld extension in sketch up pro 2021. It all seems to be working well and rejoining the geometry when I check it. however once I save the file, close it and re- open it half of the welding hasn't saved. Any ideas Why this is happening?
Which weld extension are you referring to? Is this different that the built-in Weld feature? It would be helpful if you shared a file that shows this behavior.
Register LoginAdvertisement
