    Welds not saving in sketch up pro
    2 Posts 2 Posters 3.5k Views 2 Watching
      sarahjaneboothdesign
      I've just started using the weld extension in sketch up pro 2021. It all seems to be working well and rejoining the geometry when I check it. however once I save the file, close it and re- open it half of the welding hasn't saved. Any ideas Why this is happening?
        Which weld extension are you referring to? Is this different that the built-in Weld feature? It would be helpful if you shared a file that shows this behavior.
