    Texture orientation
    2 Posts 2 Posters 3.3k Views 2 Watching
    • R
      Raimondo
      Hi, I have a problem with the application of the texture, it does'n respect my setting.
      I want to apply a texture to a curve object, so usually i apply it to the first polygon of the curve, so i set there the texture (size and orientation) and then i can go on with the color sampler tool but now when i continue to the oters segments the texture risults inverted. I have to set the texture for every segment and this is crazy. If i set the second segment texture, when i apply it to the third segment it risults again inverted.
      What is the problem?
      Thank you all
        Please share your .skp file so we can see what you have to work with.
        Are you still using SketchUp 2013 Make as indicated by your profile?
