    How to center imported files back to SketchUp's cetnerpoint?
    5 Posts 2 Posters 2.2k Views 2 Watching
    • HornOxxH Offline
      HornOxx
      Hi All - I urgently need a tip from the experts here πŸ˜„
      I have imported a big number of ifc building files - all of these files were obviously originally placed in their original geo-locations, many kilometers away from SketchUp's cetnerpoint which is causing the well-known problems now. Is there any trick to move these building models back to SketchUp's cetnerpoint now?
      never trust a skinny cook
      • BoxB Offline
        Chris Fulmer's Center on Origin will move them all for you.
        https://sketchucation.com/pluginstore?pln=clf_center_on_origin
        You can set it as a shortcut, so you can select them in the outliner and move them with a keystroke.
        • HornOxxH Offline
          HornOxx
          Hi and thank you Box πŸ‘ I installed the recommended plugin immediately πŸ˜‰
          I'm not sure if I'm on the right path now because I don't see which tool you trigger πŸ˜‰ - if it's the plugin shown below, I can't get any origin-centering done with it so far with any of the shown options.
          • BoxB Offline
            Did you restart sketchup after installing it? That is sometimes needed.
            It should look like this.
            • HornOxxH Offline
              HornOxx
              πŸ‘ πŸ‘ thanks again Box - reboot and everything ran as you showed me. thanks a lot for that valuable tip
