    Parametric Modelling - Smoothness - HELP Needed
    3 Posts 3 Posters 1.9k Views 3 Watching
    • R
      Ramvek1988
      Hi Community!
      I'm trying to create parametric curved forms but i cannot seem to create smooth flowing forms as per the image attachment. I've used the Curviloft Extension to create lofts / meshes between 2d spline profiles and then have used Slicer Extension to cut them up but I cannot seem to get them looking as smooth as image attached.
      Has anyone done this before? Know of any good extensions or techniques to create these shapes / form in sketchup?
      Would really appreciate any advice
      RVK
      • TIGT
        Your starting 'lines' as curves need to be suitably segmented, the more bits in them the smoother the 3d CurviLoft result.
        So you need to have a higher segment count in any arcs that you then weld into a complex curve.
        Fredo has some tools to change segmentation of curves/splines etc...
        My Slicer tool simply cuts up the 3d form, so you need to ensure it's suitable smooth before slicing...
          You say "Parametric Modeling" : super cool opportunity to test this new free tool! πŸ˜‰
          Parametric Modeling by SamuelT(very evoluated V 3 since this video V1! )
