Render Animation, Error failed to create dumpfile
Hello everybody,
I'm using Animator with vray on sketuchup 2021 and vray 5. I've set the time to render to 1 minute for each frame. Sometimes the rendering doesn't go to the next frame and I have to click Interrupt in the video render dialog. In the next dialog I choose Cancel. Then the rendering continues.
Since rendering the complete video takes about 46 hours, I let it run overnight. Unfortunately, the process stops every time as described above. Today I still had the message "Error create dump file". After confirming the dialog, Sketchup closed.
I'm not sure what caused the problem. With Sketchup, Animator or Vray.
I would be very grateful for any help.
Greetings Andreas
No one has this issue except of me?
Thanks for reply.
Best regards
Andreas
Register LoginAdvertisement
