    Please help me
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    3 Posts 2 Posters 7.8k Views 2 Watching
    • R
      Romanzan1990
      I use your animation plugin and suddenly the generation stopped working
      ffmpeg version 2020-10-31-git-3da35b7cc7-full_build-www.gyan.dev Copyright (c) 2000-2020 the FFmpeg developers
      built with gcc 10.2.0 (Rev3, Built by MSYS2 project)
      configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libglslang --enable-vulkan --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
      libavutil 56. 60.100 / 56. 60.100
      libavcodec 58.112.100 / 58.112.100
      libavformat 58. 64.100 / 58. 64.100
      libavdevice 58. 11.102 / 58. 11.102
      libavfilter 7. 88.100 / 7. 88.100
      libswscale 5. 8.100 / 5. 8.100
      libswresample 3. 8.100 / 3. 8.100
      libpostproc 55. 8.100 / 55. 8.100
      [image2 @ 000001b328bbe600] Could find no file with path 'Image%02d.png' and index in the range 0-4
      Image%02d.png: No such file or directory
      • R
        Romanzan1990
        there are no pictures,I think this is due to the installation of vray 5
        in the 2017 version, the image is saved,and in 2021 it is not
        • fredo6F
          fredo6
          Could you open the Ruby console while generating. This gives traces on the progression of the generation and possibly errors.
          Also open the directory where the images are generated to see if they are actually.
