    What versions of SU have .STL file export?
    8 Posts 3 Posters 10.7k Views 3 Watching
    • jgbJ
      jgb
      Right now I am stuck with SU 2015 Make on my PC that is win 10 32 bit.
      I understand that SU 2016 is the last 32 bit I can load.
      Does it support .STL file export?
      If not is there an add-on or other app that can convert SU files to .STL?
      jgb
        You can try the free PCONPlanner for many convert Version / Formats! ๐Ÿ˜‰
        Accept of course SU SKP files!
        https://pcon-planner.com
        Curious it has not STL ๐Ÿ˜ฎ ...so export in OBJ and use some other free converter like
        Mesh Mixer
        • BoxB
          The original STL extension by the sketchup team should work in your version.
          https://extensions.sketchup.com/extension/412723d4-1f7a-4a5f-b866-281a3e223337/sketch-up-stl
          • jgbJ
            jgb
            Thank you.
            I will try them.
            jgb
            • jgbJ
              jgb
              Pilou
              Both Pcon-Planner and Mesh Mixer are 64 bit apps. Can't use them. Thanks anyway.
              Box.
              Thanks again. Do you know if it will be updated?
              jgb
              • BoxB
                What do you mean? Updated how? to what? Why?
                • jgbJ
                  jgb
                  The RBZ file was created in 2015.
                  jgb
                  • BoxB
                    You were created a few years before that and you appear to still function.
                    I don't understand what you want to know. The extension works and is compatible with older and newer versions of sketchup.
