What versions of SU have .STL file export?
Right now I am stuck with SU 2015 Make on my PC that is win 10 32 bit.
I understand that SU 2016 is the last 32 bit I can load.
Does it support .STL file export?
If not is there an add-on or other app that can convert SU files to .STL? -
You can try the free PCONPlanner for many convert Version / Formats!
Accept of course SU SKP files!
https://pcon-planner.comCurious it has not STL
...so export in OBJ and use some other free converter like
Mesh Mixer -
The original STL extension by the sketchup team should work in your version.
https://extensions.sketchup.com/extension/412723d4-1f7a-4a5f-b866-281a3e223337/sketch-up-stl -
Thank you.
I will try them. -
Pilou
Both Pcon-Planner and Mesh Mixer are 64 bit apps. Can't use them. Thanks anyway.Box.
Thanks again. Do you know if it will be updated? -
What do you mean? Updated how? to what? Why?
The RBZ file was created in 2015.
You were created a few years before that and you appear to still function.
I don't understand what you want to know. The extension works and is compatible with older and newer versions of sketchup.
With your input, this post could be even better ๐
