    Edit Component with Material (Image) Outside Component
    4 Posts 3 Posters 1.7k Views 3 Watching
    • Gus RG Offline
      Gus R
      A newbie question but how can I edit a component with an image for tracing on a plane outside the component without that image fading to white when I enter the component to edit making it impossible to trace? If that's possible. I noticed it doesn't fade to white on a non-exploded image.
      www.instagram.com/gusrobatto/
      www.facebook.com/gusrobatto
      • pbacotP Offline
        Exploded it's a texture. What's wrong with tracing over an unexploded image?
        • Gus RG Offline
          Gus R
          Nothing I suppose.
            Someone had this same question recently. They were exploding the image after importing it, too. If you don't explode it, the image will show when the component is open for editing. I showed this as an example.
            It's puzzling to me that users feel the need to explode images after importing them. If it's not going to be used as a texture there's no need to explode it. If it is going to be used as a texture, it makes more sense to import it as a texture in the first place.
