    Animator
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    4 Posts 3 Posters 7.5k Views 3 Watching
      Jürgen_Deak
      hello, I follow the tool Animator with great interest. I currently have the problem that on the path the model spins without which I want this. I have also examined the path several times and found nothing wrong. what can this be about ? Regards
      Datei-1
      • fredo6F Offline
        fredo6
        Thanks for this model. It looks like a bug, or a geometrical issue with the algorithm.
        I'll have a look and come back.
        • K Offline
          keck
          runs away the group as well path.aviCiao bello Fredo. You did a great job concerning this f.....g good plug in called "Fredo6 animator" 🎉 😎 Unfortunately it seems like my birdbrain is not enough to recognize why within the attached animation the palette is running away from the group or path. I would like to place as many pallets as i want on the path, pick them up or leave them and drive through at the bottom. In other words, any number of stops and departures. Please can you tell me if this is basically possible and I just can't do it? Or that it won't work because of the program? I use v3.7 and your library v12.9. Grettings from Switzerland rolf
          • fredo6F Offline
            fredo6
            That's a tricky one, because you animate 2 groups separately and then wants that they are animated together. So, it might not be obvious to manage, although I think it is possible (but probably not straightforward).
            I'll have a lookas soon as I can.
            Fredo
