    2921 and my image exports
    14 Posts 3 Posters 2.8k Views 3 Watching
    • Joe WoodJ Offline
      Joe Wood
      Folks, I'm pretty happy with win 10 and SUp 2021 so far but ran in to the first problem, with my image exports. The text is small and washed out. Exporting at 6000 pix wide, highest image quality, with anti alias on, and off.
      this s shot is how it should look
      but this is the exported image
      Edit- looks like the lower pixel I export at the better the text quality gets.
      Joe Wood
      woodsshop.com/
      • pbacotP Offline
        Use the "should" method, then? Or is this a change, same settings, different versions?
        • Joe WoodJ Offline
          Joe Wood
          I've always exported at 6000 pix, ever since Ver 3. I learned to export big, then resize to get rid of the jaggies
          The last Ver I had was 2015, with out the Tray. So 2021 is a big change for me.
          the last 6 months I've had win 10 32 bit which was wrong, I just had the correct 64 bit OS installed 2 days back, the same day I bought 2021, was hoping for a lot better performance.
          Joe Wood
          woodsshop.com/
          • Joe WoodJ Offline
            Joe Wood
            Sorry, that Should Be image is a screenshot of my SUp window.
            Joe Wood
            woodsshop.com/
              Another new feature added since 2015. In the export options, set the Line Scale to something larger than 1. Experiment and see what you like.
              • Joe WoodJ Offline
                Joe Wood
                I didn't even see that! Mine's set at one now, what # do you think I should try for these type of images?
                Joe Wood
                woodsshop.com/
                  ! is the default. Try 2 or 3. Probably no need to go higher.
                  • Joe WoodJ Offline
                    Joe Wood
                    never mind I'm getting it! The first thing I notice and don't like is
                    when I go to 3, the text is great but the lines of the structure are heavier, a little blurry,
                    going back to 1, the text is way small but the definition and clarity are much better,
                    so it'll be a trade off?
                    Joe Wood
                    woodsshop.com/
                    • Joe WoodJ Offline
                      Joe Wood
                      what do you think about my open gl settings?
                      Joe Wood
                      woodsshop.com/
                      • pbacotP Offline
                        Can't you use a larger font size?
                        • Joe WoodJ Offline
                          Joe Wood
                          I had the font size all set up correctly as you see in this s shot
                          Joe Wood
                          woodsshop.com/
                            When you use text/dimensions in SketchUp you need to set them up correctly for the output. That's not necessarily correct for the way they appear on screen. Considering the size of your image exports, you might need to use a larger font size. This is much easier to deal with if you add the text in LayOut instead. This is a thing you and I have talked about at least twice before over the years.
                            • Joe WoodJ Offline
                              Joe Wood
                              say Dave, how would I setup text/dimensions correctly? Is this just their initial size you're talking about?
                              what size image export should I use with this 2021 if not 6000 pix wide?
                              why are the lines appearing heavy and darker, can change line weight anywhere?
                              Joe Wood
                              woodsshop.com/
                                There's nothing wrong with 6000 pixel-wide image exports. That's often what I do. As for setting the text correctly, you'll need to experiment a little to get the size you want in the image export. I don't know what size you should set because I don't know how big you want the text to appear. There is no way to set lineweight in SketchUp. There never has been. You can do that in LayOut, though and you can use Hybrid rendering so the lines in LayOut are vector lines and will generally be crisper in the exports. (Keep in mind that edges and text will become rasterized in image exports. If you export a PDF from LayOut that won't happen.) And if you use LayOut's Text, Label, and Dimension tools, you can set font size, lineweight for leaders and dimension lines and other properties to get what you want. You'll also be looking at paper space in LayOut so you can easily compare the size of the text with the overall dimensions of the exported image.
