    SketchUcation installation failure
    25 Posts 3 Posters 7.8k Views 3 Watching
    • portos52P
      portos52
      Sorry, but I don't understand your reply.
      In the first capture, you can see the Plugins directoy. Inside there is a subdirectory "Sketchucation" and one file named !SketchUcation_loader.rb. Exactly what you said should be there.
      What is wrong?
      • TIGT
        Sorry for the confusion...
        Delete the subfolder named SketchUcation.
        Reinstall from the compatible v2~ RBZ.
        Before doing anything else, open the newly re-added SketchUcation subfolder and remove the sketchUcloud.rb file.
        Now restart SketchUp.
        If there are any error messages report them here...
        Otherwise... the earlier post https://sketchucation.com/forums/viewtopic.php?p=665823#p665823 has 2 RB files you could try substituting, combined with a restart...
        Any better ?
        • portos52P
          portos52
          I followed the first way.
          Finally, this is the message error.
          "Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SketchUcation/SCF_loader.rb
          (eval):352:in require': uninitialized constant SCF::SCF::TEMP Error Loading File !SketchUcation_loader.rb (eval):352:in require': uninitialized constant SCF::SCF::TEMP"
          • TIGT
            I am very confused about this - as I expect you are !
            Shortly I'll PM a version to you to try...
            • TIGT
              I've sent you a PM with an alternative RBZ to try...
              • 2 / 2
