    SketchUcation installation failure
    25 Posts 3 Posters 7.1k Views 3 Watching
      I'm still not convinced that you have a 'clean' installation !?
      You could have some files left over from the earlier mis-installation of the newer incompatible RBZ...
      Please manually delete any Plugin subfolder named 'SketchUcation', then find any .RB file in Plugins containing the text 'SketchUcation', and delete those.
      Next install the RBZ with the old version...
      Go back through these posts and delete or substitute the files in the SketchUcation subfolder as detailed.
      Restart SketchUp and report back...
      • portos52P Offline
        portos52
        I did what you said and now I get the same error message as before:
        "Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SketchUcation/sketchUcloud.rb
        uninitialized constant SUC::SCFapi
        Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SketchUcation/SCF_loader.rb
        Error Loading File !SketchUcation_loader.rb
        uninitialized constant SUC::SCFapi"
          Please read back through the earlier posts and delete the files I told you to...
          Read this...
          https://sketchucation.com/forums/viewtopic.php?p=665823#p665823
          and replace the installed files...
          Then look in the Plugins folder's subfolder named SketchUcation - find the file [if any] named sketchUcloud.rb
          Delete that unwanted file.
          AND did you first remove all of the [newer RBZ's] files/subfolders your wrongly installed earlier ?
          You didn't confirm that...
          πŸ˜•
          • portos52P Offline
            portos52
            Yes, I followed your instructions.
            I paste the images of my directories.
              You do not seem to have installed it / or tidied up properly.
              When installed properly there should be two items in the Plugins folder.
              !SketchUcation_loader.rb [which loads the extension]
              SketchUcation [a subfolder of files used by the extension.
              You have an incompatible newer SketchUcation.rb file in your Plugins folder - which I think is causing most of your problems, and there are probably some wrong files in the subfolder too.
              Do the following...
              Delete the subfolder named "SketchUcation" and the file named "!SketchUcation_loader.rb" - so that we have a clean install...
              Now install the latest version of the RBZ for v2~ as previously supplied.
              Install it.
              You'll probably still get an error message - exit SketchUp - delete the subfolder's sketchUcloud.rb file and restart SketchUp...
              Any better ?
              • portos52P Offline
                portos52
                Sorry, but I don't understand your reply.
                In the first capture, you can see the Plugins directoy. Inside there is a subdirectory "Sketchucation" and one file named !SketchUcation_loader.rb. Exactly what you said should be there.
                What is wrong?
                  Sorry for the confusion...
                  Delete the subfolder named SketchUcation.
                  Reinstall from the compatible v2~ RBZ.
                  Before doing anything else, open the newly re-added SketchUcation subfolder and remove the sketchUcloud.rb file.
                  Now restart SketchUp.
                  If there are any error messages report them here...
                  Otherwise... the earlier post https://sketchucation.com/forums/viewtopic.php?p=665823#p665823 has 2 RB files you could try substituting, combined with a restart...
                  Any better ?
                  • portos52P Offline
                    portos52
                    I followed the first way.
                    Finally, this is the message error.
                    "Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/SketchUcation/SCF_loader.rb
                    (eval):352:in require': uninitialized constant SCF::SCF::TEMP Error Loading File !SketchUcation_loader.rb (eval):352:in require': uninitialized constant SCF::SCF::TEMP"
                      I am very confused about this - as I expect you are !
                      Shortly I'll PM a version to you to try...
                        I've sent you a PM with an alternative RBZ to try...
                        • 2 / 2
