    Perpendicular texturing
    3 Posts 2 Posters 1.5k Views 2 Watching
    • P
      pasha bell
      Hi there everyone!
      I'm new here, but i have a along experience with SketchUp.
      I have a question regarding how to texture the ground with different bricks layout.
      I will explain:
      I need to recreate this ground cover in sketchup:
      https://i.imgur.com/9Gn0COh.jpg
      I need to color most of the area with a regular brick texture, but i need to create a buffer of perpendicular bricks around each grass polygon:
      https://i.imgur.com/AUGm4oL.jpg
      Problem 1: I don't want to draw and then paint every individual brick (it's a huge and amorphic area) and then roteting the texture for each one...
      Problem 2: I just don't know how to do it effective and quick.
      Please help, SketchUp geniouses!!!
      • pbacotP
        Hi. I am not sure from your profile but you may be using a version that can use plugins. In that case I'd use Fredo's ThruPaint plugin:
        In any case the article helps explain how the segmenting of the curved border is important--and there may be other plugins to get the same effects in texturing.
        To subdivide the border you may want to look at TIG's SPLIT TOOLS
        https://sketchucation.com/resources/tutorials/intermediate/1764-arch-texturing-in-sketchup-with-thrupaint
        You will find more information and videos about ThruPaint in the forum subject for the plugin.
        • P
          pasha bell
          Thanks so much pbacot! It's a great sulution indeed!
          I have posted on the tool's post - a question on how to get the segmentation right.
          Maybe you'll have an insight as well:
          https://sketchucation.com/forums/viewtopic.php?f=323&t=43371
          Thanks again!!
