    Can't open my skp files
    11 Posts 3 Posters 2.2k Views 3 Watching
    • Joe WoodJ Offline
      Joe Wood
      Folks, I use SUp 2015. I needed ver 2016 to open a 3d warehouse model so I downloaded 2016 Make. Then I Removed it after saving the file as 2015.
      now I can't open any 2015 skp files that are in folders, like this s shot. I need to open the 2015 shortcut on my desktop, and browse to the skp file in order to open it.
      what can I do??
      Joe Wood
      woodsshop.com/
        Does this a big deal ? What do you want more speed ?
        • Joe WoodJ Offline
          Joe Wood
          Yes it's a big deal, I can't open my 2015 skp files from within their folder, in that s shot you see they're grayed out. You might have misread my post?
          Joe Wood
          woodsshop.com/
            Ah Ok... 😳
            Can you post a little example of a SU 2016 SKP ?
            For I make the same as you...
            • Joe WoodJ Offline
              Joe Wood
              Yeah I can only use my 2015 when I open the main shortcut then browse to the skp I want. This started when I installed / uninstalled 2016.
              I thought it might be my File Associations, went to look but see this message, says to look for an app?
              I'm sitting here now using SUp 1015, on a win 10 machine.
              Joe Wood
              woodsshop.com/
                I have 2015,2016,2017 "Make" installed...any problem for make any save and reload in any version
                (up or down versions for compatibility)
                And why not keep the 2016 generating the 2015 file whished?
                • Joe WoodJ Offline
                  Joe Wood
                  because I thought Removing it would solve this problem.
                  weird it shows no SUp app in that file association window
                  Joe Wood
                  woodsshop.com/
                  • BoxB Offline
                    2016 is now seen as the default but its not there for it to use so it doesn't know what to do.
                    If you have the 2015 install.exe run it as administrator and choose 'repair'.
                    • Joe WoodJ Offline
                      Joe Wood
                      Right on Frenchy I'll try that, in the meantime I can R click and use
                      Open With 2015
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ Offline
                        Joe Wood
                        Yeah I don't have that install.exe darn it.
                        Joe Wood
                        woodsshop.com/
                        • BoxB Offline
                          Perhaps the links in this thread will help.
                          https://sketchucation.com/forums/viewtopic.php?f=179&t=72193
                          https://www.sketchup3d.de/download/center/#199-183-version-2015
