    Can't open my skp files
    11 Posts 3 Posters 2.5k Views 3 Watching
      I need to open the 2015 shortcut on my desktop, and browse to the skp file in order to open it.
      Does this a big deal ? What do you want more speed ?
      • Joe WoodJ
        Joe Wood
        Yes it's a big deal, I can't open my 2015 skp files from within their folder, in that s shot you see they're grayed out. You might have misread my post?
        Joe Wood
        woodsshop.com/
          Ah Ok... 😳
          Can you post a little example of a SU 2016 SKP ?
          For I make the same as you...
          • Joe WoodJ
            Joe Wood
            Yeah I can only use my 2015 when I open the main shortcut then browse to the skp I want. This started when I installed / uninstalled 2016.
            I thought it might be my File Associations, went to look but see this message, says to look for an app?
            I'm sitting here now using SUp 1015, on a win 10 machine.
            Joe Wood
            woodsshop.com/
              I have 2015,2016,2017 "Make" installed...any problem for make any save and reload in any version
              (up or down versions for compatibility)
              And why not keep the 2016 generating the 2015 file whished?
              • Joe WoodJ
                Joe Wood
                because I thought Removing it would solve this problem.
                weird it shows no SUp app in that file association window
                Joe Wood
                woodsshop.com/
                • BoxB
                  2016 is now seen as the default but its not there for it to use so it doesn't know what to do.
                  If you have the 2015 install.exe run it as administrator and choose 'repair'.
                  • Joe WoodJ
                    Joe Wood
                    Right on Frenchy I'll try that, in the meantime I can R click and use
                    Open With 2015
                    Joe Wood
                    woodsshop.com/
                    • Joe WoodJ
                      Joe Wood
                      Yeah I don't have that install.exe darn it.
                      Joe Wood
                      woodsshop.com/
                      • BoxB
                        Perhaps the links in this thread will help.
                        https://sketchucation.com/forums/viewtopic.php?f=179&t=72193
                        https://www.sketchup3d.de/download/center/#199-183-version-2015
