How to Get Rid of the 'Ground'? In Vray Rendering
Hi. Is there anyone that could help me with this please?
I'm doing a kindergarten room but somehow it gets stuck with a 'ground' showing in the image attached. It never happens to my other modeling before and it's so weird none of the Ground settings is turned on, HDRI background was set to Sphere as well, NOT hemisphere, but the 'ground' is still there... in vray rendering no matter how I change the model... I've tried everything...
Please help.
Stupid question, do you have an infinite plane in your scene?
There is a Ground option in Dome Light but it is not on by default.
Also, when you add HDRI using Dome Light, you select Spherical under Texture Placement /Mapping option. But you need to check that under Dome Light you select Sphere as well.
I think this would help you. -
Figured it out yesterday. Had the Geoplane in vray on, then turned it off.
I don’t think any question is ever stupid. It happens.
Register LoginAdvertisement
