    How I make the shapes with curviloft
    18 Posts 3 Posters 7.2k Views 3 Watching
    • Bryan KB
      Curviloft can be downloaded from here.
      https://sketchucation.com/pluginstore?listtype=3&author=0&category=0
      First make a box.
      • Bryan KB
        Next, delete 3 sides.
        • Bryan KB
          Next draw straight lines to use as guides and part of the final solid model.
          • Bryan KB
            Now use the basic arc tool and draw arcs.
            • Bryan KB
              Further refine the arcs so the corners are not pointy.
              • Bryan KB
                Draw new guideline on the bottom and repeat the process with arcs and then smaller arcs on the corners.
                In this case, I just drew one arc to make a perfect corner arc.
                • Bryan KB
                  Now erase all the guidelines and just leave the 3 sided arc faces.
                  • Bryan KB
                    And that's it! Add detail as needed by making and using separate components.
                    • Bryan KB
                      Make the model a component or group. I make components based on Front, Rear, Top and Bottom. So four final components for each quarter.
                      Duplicate and flip each one to make final shape. Then scale top or bottom as you see fit. I usually scale the bottom to be shorter than the top.
                      • Bryan KB
                        Select all the outer edges with Curviloft.
                        This is a different image but essentially the same process. Somehow the original image export became corrupted and then deleted itself.
                        The click the small green checkmark and the big checkmate which will appear.
                          Cool tuto 😎
                          Seems you can have same result with Extrude Tools by Tig from this step πŸ˜‰
                          (sure with less options after the mesh creation)
                          or here Ferrari πŸ˜‰ (with some options after the mesh creation)
                          • ntxdaveN
                            ntxdave
                            Very interesting process Bryan. I did some of it (enough to understand the process). I had to try several times to get the lines and arcs all connected properly to that CurviLoft would work correctly.
                            Want to experiment a little with the types of CurviLoft so I understand the differences better.
                            Thanks for sharing..............Now I will have to go off and try to be "inventive". πŸ‘ πŸ‘
                            Press F1...thank me later
                            • Bryan KB
                              That IS the trick. It does take some fiddling. If the arcs aren't connected just perfect, it will not work. Be sure to connect arcs on "points" (green dots) and not "midways" (blue dots).
                              You're welcome. My pleasure. Many people here have helped me over the years and I am happy I can do anything to pay back or pay forward any way I can.
                              • Bryan KB
                                • Bryan KB
                                  @pilou said:
                                  Cool tuto 😎
                                  [attachment=1:9phm9ipl]<!-- ia1 -->ferar.jpg<!-- ia1 -->[/attachment:9phm9ipl]
                                  Oh that is cool. Nice!
                                  Extrude tools are what I've been looking for some time but forgot what it was called. Thanks!
                                  And just installed and yes, this is what I've been looking for quite some time. πŸ‘
                                  Ah, but it does not work on straight edges nor too many compound curves. Still, very handy tool.
                                    Extrude Tools
                                    Yes you must first divided straight lines and recurve (weld (by Diggsey) & also Curves πŸ€“
                                    • Bryan KB
                                      Extrude Tools
                                      Ah! Thanks! πŸ‘
                                      • Bryan KB
                                        You now have a quarter of your final shape.
                                        IMPORTANT! Make sure you EXPLODE the Curviloft shape or it will only be a shell and not a solid model. Exploding it welds it back to the lines you used to create it, giving it the flat inner sides and bottom and a fully enclosed model. This makes it easier to modify later.
