    Vertex Gizmo question
    Scheduled Pinned Locked Moved SUbD
    renderpluginsextensions
    4 Posts 3 Posters 19.3k Views 3 Watching
    • Z Offline
      Zaacharms
      Is there a way to rotate with vertex tools in a plane that's different the default?
      I'd like to rotate in the plane of the part not the global system.
      Secondly, can the gizmo be re-positioned to a specific node?
      Thanks again,
      Marc
        McGordon
        Right-click->Gizmo->Align to Custom
        Then either choose a point and 3 axes, or shift click on a face or vertex.
        To set to a specific 'node' choose an endpoint.
        • Z Offline
          Zaacharms
          Thank you.
          Lot of helpful stuff under the R-click button! Probably should have found that myself.
          Marc
            @zaacharms said:
            Thank you.
            Marc
            The next version should make the options easier to discover. πŸ˜„
