    Downloading issues
    6 Posts 4 Posters 2.0k Views 4 Watching
    • J
      jo901
      I'm trying to download JHS toolbar and each time I attempt it a new SketchUp model page opens with a dialog box telling me that "this appears not to be a model" which then as you click it, to get rid of the dialog box, sketch up closes. Any help appreciated,
      Thanks Jo
      • J
        jo901
        I watched the video on downloading the JHS toolbar, when I go to window, preferences extensions as instructed- there is no extensions option. can anyone advise.
          Can you post the model that you want to load ?
          • TIGT
            When you download an extension [.RBZ file] your web-browser prompts of an action.
            Typically this is to open the file or to save it.
            If you [wrongly] choose to open it, and you have that RBZ file-type [wrongly] associated with SketchUp, then it will attempt to open in SketchUp ! But of course it's not a SKP file so you get that error message.
            So you must choose to save it - typically the RBZ gets saved into your Downloads folder.
            Then you need to install it in SketchUp...
            Open the SketchUp "Extension Manager"***, and in its dialog use the red-button to "Install extension..."
            Find the RBZ [in your Downloads folder ?]...
            It will be automatically unpacked into the relevant files and subfolders within your User Plugins folder... then its loaded and creates the related menu and toolbar entries...
            ***In old SketchUp versions the Extensions were accessed through the Preferences menu item, but in the newer SketchUp versions there's a separate "Extension Manager" entry in the SketchUp Window menu list...
            If you have somehow sidestepped the web-browser's 'choices' prompt, e.g. so it goes directly to 'open' - then you should be able to change some options in your web-browser's settings to revert for the RBZ file-type to either saving directly to your Downloads folder or prompt for a save location etc...
            Here's my Firefox options settings - always-save...
            Other browsers will have similar set ups...
            • jujuJ
              juju
              search the PluginStore, locate extension, download onto local machine, install using the Extension Manager
              • jujuJ
                juju
                @jo901 said:
                Thanks Jo
                please do not start duplicate threads
