    Animator plugins
    3 Posts 3 Posters 1.9k Views 3 Watching
    • D
      drafter
      I've got three animation plugins; Sketchy Physics, MSPhysics and Fredo6 Animator.
      Is the latter meant to replace the first two, or does each have its own advantages?
      I'm using Make 2017.
        Ms Physics can be the replacement of the old SketchyPhysics!
        Animator is completly different, you don't code with it so more easy!
        A complete teaching (26 steps)
        • fredo6F
          fredo6
          Physics-based engine takes constraint and simulate the result of a movement, considering these constraints (joints, gravity, etc...).
          In Animation plugins (like Animator), you really specify each movement of objects and cameras. So it's not a simulation. Indeed, you have more control on the result, since it is always exactly what you designed.
          Both have their learning curve and need practice.
