    VRAY Next: Add Dirt texture to a Material?
    renderpluginsextensions
    2 Posts 2 Posters 5.2k Views 2 Watching
    • V
      volfonisenior
      Hello,
      I want to add a dirt texture to a Vray Material, and I can't find a way to add the dirt layer.
      For example, I use a Stucco from the Vray Preset Material Library and try to add the Dirt texture over it with transparency, but it won't work!
      Does somebody has the solution?
      • GD3DesignG
        GD3Design
        Make a blend material with stucco as base and dirt material over top, set dirt to 'multiply' (blend or comptex...ahh, here it is------> https://docs.chaosgroup.com/display/VNFS/Mix+Operator
