    Product render.
    10 Posts 5 Posters 2.0k Views 5 Watching
      Just a mixer tap with a studio light set up. There are very low level light sources in the handles.
      Just a mixer tap unit.
      • Mike LuceyM Offline
        Mike Lucey
        Flawless!
          Thank you.
          • Bryan KB Offline
            Perfect!
            • HornOxxH Offline
              HornOxx
              wunderbar! πŸ‘ how did you make this rippled(?) handles and which renerer was in use here?
              never trust a skinny cook
              • pbacotP Offline
                Beautiful! When you do flawless metal like that is the material mapped or is it just a solid color that has a metal template assigned to it?
                • HornOxxH Offline
                  HornOxx
                  @mike amos said:
                  ...It took forever but the handle sub unit was a group copied and pasted so only the one job.
                  πŸ˜„ πŸ‘ πŸ‘ may I see this handle geometry (it is good!)
                    Thanks folk, the texture is a solid colour with a stainless steel finish applied in Twilight V2. The handles are geometry, offset tool and push/pull tool. It took forever but the handle sub unit was a group copied and pasted so only the one job.
                    Geometry.
                      Handle, best way to see it.
                      Handle
                      • HornOxxH Offline
                        HornOxx
                        πŸ‘ πŸ‘
