⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Product render.
10 Posts 5 Posters 1.6k Views 5 Watching
    Just a mixer tap with a studio light set up. There are very low level light sources in the handles.
    Just a mixer tap unit.
      Mike Lucey
      Flawless!
        Thank you.
          Perfect!
          • H Offline
            HornOxx
            wunderbar! πŸ‘ how did you make this rippled(?) handles and which renerer was in use here?
            never trust a skinny cook
              Beautiful! When you do flawless metal like that is the material mapped or is it just a solid color that has a metal template assigned to it?
              • H Offline
                HornOxx
                @mike amos said:
                ...It took forever but the handle sub unit was a group copied and pasted so only the one job.
                πŸ˜„ πŸ‘ πŸ‘ may I see this handle geometry (it is good!)
                  Thanks folk, the texture is a solid colour with a stainless steel finish applied in Twilight V2. The handles are geometry, offset tool and push/pull tool. It took forever but the handle sub unit was a group copied and pasted so only the one job.
                  Geometry.
                    Handle, best way to see it.
                    Handle
                    • H Offline
                      HornOxx
                      πŸ‘ πŸ‘
