    Sketchup 2018 Pro not showing mapped network drives
    3 Posts 3 Posters 1.2k Views 3 Watching
      Dik Harrison
      My copy of SketchUp 2018 Pro on my laptop no longer shows my mapped network drives in the window when I select to load a file. I can drill down to the needed shared folder, even though that folder is set up as a mapped drive. This used to work but has changed recently, not sure what update did it. Anybody have his issue or a solution?
      Have fun...
      Dik
        slbaumgartner
        There has been no change to SketchUp 2018, so the cause must be an OS or network update.
        • JD HillJ Offline
          JD Hill
          Maybe worth mentioning that if you run a program as admin, it won't see drives you mapped as your user.
          Developer - Bella Render
