    Scenes/Groups/Open/Close/Repetition
    11 Posts 4 Posters 11.6k Views 4 Watching
    • S
      SerCroJoe
      Hi. I don't know whether this is already possible:
      I frequently go back and forth between two parts of a model (2 Scenes); this means having to open/close groups repeatedly, wasting much time. Is this something that can be saved with Scenes to make it happen automatically?
      I'm using old SU 8 at the moment. Thanks.
      https://3dwarehouse.sketchup.com/model/419f646dcd29d7ab3f5cfb2966292c1b/Junk-Yard-of-Parts
      • S
        SerCroJoe
        @box said:
        Changing scenes shouldn't effect the open/close status of a group/component.
        What I meant is that one part is OUTSIDE of the other part (by several levels), so it is necessary to re-open/enter the group I've just left. Do you understand? Am I missing something? Thanks.
        • BoxB
          So it has nothing to do with scenes, are you talking about nesting of groups/components and how to get in and out of them for editing?
          • S
            SerCroJoe
            Scenes or not, I just want to click a button and be taken to one or the other area and automatically be inside however many levels of nested grouping to be able to work on whatever part it may be.
            For example, I have that Junk Yard, as I call it, where I pick out a part I need, then I fly back to where I was working. The Junk Yard is outside of all other parts and components, so in order to grab a component I need, I must exit/close several times, and then enter/open several times again to resume working. Making sense now?
            I could've sworn that years ago I didn't need to do this. I recently resumed playing around with SU after a long hiatus, hence relearning some things.
            Thanks for your attention.
            • BoxB
              I must be missing something so I'll leave it to other smarter users to help you out.
              • S
                shawb
                Create a Local Collection of the components in the junk yard and display with large thumbnails in the Component tray. That way the components will be available at whatever group/component level you happen to have open. Maybe easier than trailing around a junk yard trying to spot what you need?
                • S
                  SerCroJoe
                  I think I know what you mean. I think I was trying to avoid that because of how many components I'd be dealing with (I assume each comp. must be added separately). It certainly would be quicker and easier if the settings could be saved with the Scenes, but I will reconsider this alternative way. Thank you. πŸ˜„
                  • K
                    kaas
                    Using the outliner you can easily jump from one nested group into another without manually opening/closing groups or components.
                    • S
                      shawb
                      Use the 'Save as a local collection' option in the component tray tab. This will save all the components in the model as separate SKPs to a folder of your choice. Use 'Open or create a local collection' to bring in your junk yard items.
                      • BoxB
                        • S
                          SerCroJoe
                          Thanks, shawb, Box, kaas. πŸ˜„
