    Seeing the thumbnails
    12 Posts 3 Posters 3.1k Views 3 Watching
    • Joe WoodJ
      Joe Wood
      What is that app / whatever, I need to see the SUp t nails? Just had win 10 installed on my system and lost whatever that was.
      Joe Wood
      woodsshop.com/
        Doesn't changing the View to Large Icons show the thumbnails? It does for me.
        • Joe WoodJ
          Joe Wood
          Right on Dave that works!
          Joe Wood
          woodsshop.com/
          • Joe WoodJ
            Joe Wood
            Is there a setting to make all folders open up with large icons instead of needing to select View > large icons?
            Joe Wood
            woodsshop.com/
              Once you set them in the explorer window, they should open that way in the future. At least they do for me.
              • Joe WoodJ
                Joe Wood
                Do you mean once you set one folder to large, the others will also be large? That's not the case for me, I keep needing to change the new folders I open.
                Joe Wood
                woodsshop.com/
                  No. That's not what I mean. When I set a folder to display thumbnails it does that when I open it again.
                  • Joe WoodJ
                    Joe Wood
                    could you explain how to do it thru windows explorer Dave?
                    Joe Wood
                    woodsshop.com/
                      I just open the folder and set it to show the thumbnails. When I open the Explorer window the next time, the thumbnails are displayed. If I want the details instead, I change it to show them. The next time I go to that folder it shows details. If that's not happening for you maybe you need a Windows expert to help.
                      • BoxB
                        Under File you have Change Folder and Search options. You can set the view there and apply it to all folder.
                        • Joe WoodJ
                          Joe Wood
                          Right on Box, thanks for that,
                          one less aggravation!
                          Joe Wood
                          woodsshop.com/
                          • Joe WoodJ
                            Joe Wood
                            That View> large icons fix didn't stick, so I asked on the MS support forum
                            The tutorial below can help show you how to set a default folder template for all folders, change the layout to large icons for how you want, and then apply to all folders.
                            https://www.tenforums.com/tutorials/35192-set-default-folder-view-all-folders-windows-10-a.html
                            Joe Wood
                            woodsshop.com/
