    Seeing the thumbnails
    12 Posts 3 Posters 3.0k Views 3 Watching
    • Joe WoodJ Offline
      Joe Wood
      Right on Dave that works!
      Joe Wood
      woodsshop.com/
      • Joe WoodJ Offline
        Joe Wood
        Is there a setting to make all folders open up with large icons instead of needing to select View > large icons?
        Joe Wood
        woodsshop.com/
          Once you set them in the explorer window, they should open that way in the future. At least they do for me.
          • Joe WoodJ Offline
            Joe Wood
            Do you mean once you set one folder to large, the others will also be large? That's not the case for me, I keep needing to change the new folders I open.
            Joe Wood
            woodsshop.com/
              No. That's not what I mean. When I set a folder to display thumbnails it does that when I open it again.
              • Joe WoodJ Offline
                Joe Wood
                could you explain how to do it thru windows explorer Dave?
                Joe Wood
                woodsshop.com/
                  I just open the folder and set it to show the thumbnails. When I open the Explorer window the next time, the thumbnails are displayed. If I want the details instead, I change it to show them. The next time I go to that folder it shows details. If that's not happening for you maybe you need a Windows expert to help.
                  • BoxB Offline
                    Under File you have Change Folder and Search options. You can set the view there and apply it to all folder.
                    • Joe WoodJ Offline
                      Joe Wood
                      Right on Box, thanks for that,
                      one less aggravation!
                      Joe Wood
                      woodsshop.com/
                      • Joe WoodJ Offline
                        Joe Wood
                        That View> large icons fix didn't stick, so I asked on the MS support forum
                        The tutorial below can help show you how to set a default folder template for all folders, change the layout to large icons for how you want, and then apply to all folders.
                        Security Check
                        (www.tenforums.com)
                        Joe Wood
                        woodsshop.com/
