    Bug in Apparition Movement
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    2 Posts 2 Posters 4.7k Views 2 Watching
    • X Offline
      xxxnova
      Hi Fredo,
      I've found some bugs, that annoy so much.
      I've only select one object that would be assigned with apparition movement,
      But other object with same shape who not selected are applied with this apparition too automatically, i just need this apparition only work on my selected object.
      Is this just occurred only on my Animator?
      Would be great if this problem was solved.
      • fredo6F Offline
        fredo6
        @xxxnova said:
        Hi Fredo,
        It's probably because your object is a component instance which is itself embedded in another component instance which exist in several copies in the model.
        In Sketchup, can you modify your object manually, say add a line, and see what happens to the rest of the model.
        anyway, posting the model would help.
        Fredo
