    How to Change the Extension's UI from the Ruby Script?
    2 Posts 2 Posters 5.7k Views 2 Watching
    • H
      huajiet
      Dear Sketchucationers,
      Looking for a quick intro/tutorial into how to manipulate the UI aspect of .rb scripts. For example, how can I change where an extension appears on the menu bar? or how can I change the items that appear in the context-click menu? Some Ruby tips appreciated too!
      • TIGT
        Look through my RB scripts and see how this is done in detail...
        for a simple menu item
        SUBMENU=UI.menu("Plugins").add_submenu("Haujiet") #Or other menu by name e.g. 'Tools'
        SUBMENU.add_item("Add..."){Sketchup.active_model.select_tool(Haujiet_Tool.new())}
        SUBMENU.add_item("Settings..."){Haujiet_Module;;settings()}
        for a command
        CMD1=UI;;Command.new("Tool_name"){Haujiet_Module;;some_module_action()}
        CMD1.tooltip="How_to_use_tool..."
        CMD1.status_bar_text="How_to_use_tool..."
        CMD1.small_icon=File.join(FOLDER_path, 'icon.png')
        CMD1.large_icon=File.join(FOLDER_path, 'icon.png')
        and for Toolbar
        TOOLBAR=UI;;Toolbar.new("Haujiet...")
        TOOLBAR.add_item(CMD1)
        TOOLBAR.restore if TOOLBAR.get_last_state.abs == 1 #TB_VISIBLE/NEVER
        for a context menu
        UI.add_context_menu_handler{|menu|
          sub = menu.add_submenu("Haujiet...")
          sub.add_item(CMD1)
          # perhaps with tests to see if it should show - e.g. the selection is a group?
        See here...
        http://ruby.sketchup.com/UI/Command.html
        http://ruby.sketchup.com/UI/Toolbar.html
