    Animator - V-Ray Next
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    7 Posts 5 Posters 7.7k Views 5 Watching
      ChrisHendo
      I am sucessfullly animating a scene using Animator, however, when selecting the V-Ray rendering function the animation output is "still" at the point of the initial camera location. I'm using SketchUp Pro 2019 and V-Ray Next on Mac OS....any ideas on how I can rectify, thank you.
        architectjack
        ChrisHendo,
        I am having the same problem on Sketchup Pro 2018 and V-Ray Next Build 4.20 on PC. Did you find the cause of the problem?
        Thanks,
        Jack
        • E Offline
          emmearch
          I seem to recall the animator plugin isn't compatible with the latest version of Vray.
            architectjack
            OK thanks, I will try a different installation to see if there is any change
            • fredo6F Offline
              fredo6
              I just installed VRay v4.2 and can confirm the problem: VRay ignores the movement of objects and just render a sequence of the same original scene.
              I am contacting Chaos Group to find out.
              Fredo
              • fredo6F Offline
                fredo6
                The problem with VRay 4.2 rendering should be fixed with LibFredo6 v10.9a.
                Thanks to report if this works for all of you.
                Fredo
                  Calcifer
                  Hi Fredo,
                  It works for me perfectly now. Thank you very much
