    Moving a 3D figure along a Bezier curve
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    3 Posts 3 Posters 5.0k Views 3 Watching
    • A
      aero66
      Is there a way to keep a 3D Figure parallel to the global Z-axis when moving along a spiral curve created as a Bezier curve? My figure rotates as it moves along the curve.
      Staircase.skp
        Maybe Copy along a curve by Anton ?
        • fredo6F
          fredo6
          In your model, you should create a Movement "Follow Path".
          • Select the character
          • Select the path
          • Make sure that
            • Reverse direction is checked (because your curve in going top to down)
            • Object rotation is unchecked (to keep the guy upright)
