Sketchup Ram usage problem
I am working on a large model around (600mb) with SKP19 and Vray Next. Most of the scenes are rendering fine except one scene (vray stuck at building light cache and using almost 100% of the ram and very little of cpu). My computer is equipped with i9-9900k, rtx 2060 with 2666mhz-32gb ram and I cannot believe it is struggling with this file. Other scenes are using about 40-50 % of the ram. Last night I started a batch render before leaving work and after 13-14 hours the scene was stuck at 60-70% at prepass lol and I tried almost everything to optimize the file and still no luck. I tried cutting just the objects in the visible scene to a different file and still no luck tried purging the file about 100 times. Usually my computer works and renders fine with files above 1gb just fine.
Try disabling displacement.
Register LoginAdvertisement
