    Issue making 3D Terrain: Google and JointPushPull
    9 Posts 5 Posters 1.7k Views 5 Watching
      TorreyBW
      I thought it would be really neat to have 3D terrain that was a solid, like a physical model from elevation slices. Idea from TheSketchupEssentials (https://www.youtube.com/watch?v=-Pxl0pjOkW0&t=207s). I imported terrain data, made it a solid with Fredo6's JointPushPull Vector Push Pull tool, with option "project shape onto a plane". I've tried hiding lines, but I still see white show through at oblique angles. Any ideas?
        Can you share the SKP file so we can look at it?
        Generally I wouldn't think of using Joint Push/Pull for the task.
          TorreyBW
          This shows the lines better
            TorreyBW
            Here you are!
              I don't see the file.
              • BoxB Offline
                looks like you have hidden the geometry rather than smoothed it.
                • cottyC Offline
                  cotty
                  Do you really need all that internal geometry? Did you use the option in JPP to create it?
                  my SketchUp gallery
                    TorreyBW
                    Looks like the file is too large to upload here, hence why it didn't show up in my previous comment. Here's a link to the file where I host it in a cloud account: https://ln2.sync.com/dl/ea3e5f7c0/jnucurw9-xhbtu6m5-3x3nk9p8-bzxt6zpn
                    I definitely do not need all that internal geometry! I think that's why the file is so obnoxiously large. Does anyone have a good trick to make an object hollow? I am starting to think either I am missing some menu options in JointPushPull, or this is really not the tool to be using here.
                    I manipulated the surface with sandbox tools a little and found that when I pushed/pulled, it also pished/pulled the bottom surface, which I intended to be flat! I think I am down the wrong path for how I want to be working with this model...
                    • U Offline
                      unearthed
                      Have you got the original contours?
                      If not use SUs native contours tool to make a set and then use Fredo's Toposhaper to make a new surface, this tool will also add sides to your terrain and usually makes a solid.
                      JPP is the wrong tool for this
                      Of course work in a file copy, and at the end del everything else.
                      Growplan - People ∩ Plants ∩ Place
                      windows 7 64b, 4GB RAM, SU 8.0.16846
                      Gimp, QGIS, Vectorworks 12, Bricscad 11
