    Issue making 3D Terrain: Google and JointPushPull
    9 Posts 5 Posters 2.0k Views 5 Watching
    • T
      TorreyBW
      I thought it would be really neat to have 3D terrain that was a solid, like a physical model from elevation slices. Idea from TheSketchupEssentials (https://www.youtube.com/watch?v=-Pxl0pjOkW0&t=207s). I imported terrain data, made it a solid with Fredo6's JointPushPull Vector Push Pull tool, with option "project shape onto a plane". I've tried hiding lines, but I still see white show through at oblique angles. Any ideas?
        Can you share the SKP file so we can look at it?
        Generally I wouldn't think of using Joint Push/Pull for the task.
        • T
          TorreyBW
          This shows the lines better
          • T
            TorreyBW
            Here you are!
              I don't see the file.
              • BoxB
                looks like you have hidden the geometry rather than smoothed it.
                • cottyC
                  cotty
                  Do you really need all that internal geometry? Did you use the option in JPP to create it?
                  my SketchUp gallery
                  • T
                    TorreyBW
                    Looks like the file is too large to upload here, hence why it didn't show up in my previous comment. Here's a link to the file where I host it in a cloud account: https://ln2.sync.com/dl/ea3e5f7c0/jnucurw9-xhbtu6m5-3x3nk9p8-bzxt6zpn
                    I definitely do not need all that internal geometry! I think that's why the file is so obnoxiously large. Does anyone have a good trick to make an object hollow? I am starting to think either I am missing some menu options in JointPushPull, or this is really not the tool to be using here.
                    I manipulated the surface with sandbox tools a little and found that when I pushed/pulled, it also pished/pulled the bottom surface, which I intended to be flat! I think I am down the wrong path for how I want to be working with this model...
                    • U
                      unearthed
                      Have you got the original contours?
                      If not use SUs native contours tool to make a set and then use Fredo's Toposhaper to make a new surface, this tool will also add sides to your terrain and usually makes a solid.
                      JPP is the wrong tool for this
                      Of course work in a file copy, and at the end del everything else.
                      Growplan - People ∩ Plants ∩ Place
                      windows 7 64b, 4GB RAM, SU 8.0.16846
                      Gimp, QGIS, Vectorworks 12, Bricscad 11
