    Partial randomization of a grid of symbols
    7 Posts 4 Posters 1.8k Views 4 Watching
    • U Offline
      unearthed
      Hi all, I want to joggle the positions of a lot of symbols that are on a radial grid - see jpg attached. I thought there was a script that would joggle the positions of many objects according to simple parameters (like my example in the enc. jpg), but it mustve been a false memory!
      Does anyone have a script that will at least randomize a rectangular or square grid?
      The case is an experimental acoustic planting based on sonic crystal theory. The original rule this came from was:
      "each tree is moved from its regular position, and placed randomly in the zone equal to 1/5th of the distance in between the trees". That was written for a square grid though.
      Either my rule or the one above would be great.
      WTG.189_forRAND.skp
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • BoxB Offline
        One sort of manual way would be to use random select, then move those selected, rinse and repeat.
        SketchUp Plugins | PluginStore | SketchUcation
        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
        (sketchucation.com)
          Seems you can make something with Make Fur!
          And for radial gride Work Plane by Tig
          • PixeroP Offline
            Pixero
            You could try with my plugin: https://sketchucation.com/pluginstore?pln=JS_Random_Move
            • U Offline
              unearthed
              Thanks everyone for your ideas - sdmitch kindly sent me a short script which did the trick.
              Interesting looking plugin Pixero but I couldn't get it to move anything, I'm using su8.
              • PixeroP Offline
                Pixero
                @unearthed
                See PM.
                • PixeroP Offline
                  Pixero
                  I have updated the script to 1.1 now with support for older SketchUp and some new features.
