    Partial randomization of a grid of symbols
    7 Posts 4 Posters 1.4k Views 4 Watching
    • U Offline
      unearthed
      Hi all, I want to joggle the positions of a lot of symbols that are on a radial grid - see jpg attached. I thought there was a script that would joggle the positions of many objects according to simple parameters (like my example in the enc. jpg), but it mustve been a false memory!
      Does anyone have a script that will at least randomize a rectangular or square grid?
      The case is an experimental acoustic planting based on sonic crystal theory. The original rule this came from was:
      "each tree is moved from its regular position, and placed randomly in the zone equal to 1/5th of the distance in between the trees". That was written for a square grid though.
      Either my rule or the one above would be great.
      WTG.189_forRAND.skp
      Growplan - People ∩ Plants ∩ Place
      windows 7 64b, 4GB RAM, SU 8.0.16846
      Gimp, QGIS, Vectorworks 12, Bricscad 11
      • BoxB Offline
        One sort of manual way would be to use random select, then move those selected, rinse and repeat.
        https://sketchucation.com/pluginstore?pln=RandomSelect
          Seems you can make something with Make Fur!
          And for radial gride Work Plane by Tig
          • PixeroP Offline
            Pixero
            You could try with my plugin: https://sketchucation.com/pluginstore?pln=JS_Random_Move
            • U Offline
              unearthed
              Thanks everyone for your ideas - sdmitch kindly sent me a short script which did the trick.
              Interesting looking plugin Pixero but I couldn't get it to move anything, I'm using su8.
              • PixeroP Offline
                Pixero
                @unearthed
                See PM.
                • PixeroP Offline
                  Pixero
                  I have updated the script to 1.1 now with support for older SketchUp and some new features.
