    Animator won't continue past the first render in v-ray
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    4 Posts 2 Posters 8.5k Views 2 Watching
      lasswt
      Hello
      I'm having an isssue where the rendering of the animation won't progress past the first image automatically.
      The text in the render window in v-ray says:
      'progressive rendering finished: specified noise level reached.'
      Don't know if this helps, but if I press the stop button within the v-ray render window it continues to the next frame (both in v-ray and animator).
      Thanks in advance.
      • fredo6F Offline
        fredo6
        The API to Vray is very poor actually and does not allow Animator to be aware of what Vray is doing, whether it has finished or failed a frame image.
        I should take it to the VRay developers, but I am not sure Animator is on the top-list of rendering software in general.
          lasswt
          Thanks for the reply.
          The strange thing is that it has worked before, but I can't remember what was different.
          • fredo6F Offline
            fredo6
            May be your setting in VRay. Try to make the rendering not too heavy in calculation. You should test it before.
