    Sketchup offset corner Loop irregularity
    8 Posts 3 Posters 2.6k Views 3 Watching
    • J
      jackg00
      Hi Everyone.
      I have been using Sketchup Make for some time and I have recently downloaded a trial of Sketchup Pro, on Mac.
      I have noticed that there seems to be a bit of an anomaly between the 2 with offsetting. The problem has been happening across a lot of projects, I regularly get different geometry from tutorials.
      I have a simple example which highlights the problem. I copied the same shape from Pro to Make, its a 32s arc split in half, finished into a quarter circle shape.
      On Make no problem offsetting.
      On Pro it creates extra corner loops.
      (Pictures attached)
      Could someone let me know whether this is a setting, or something I may be doing, or potentially a bug.
      I would be grateful for any help. Thank you in advance.
      Make
      Pro
        I don't have any problem offsetting a simple pie shape in 2019.2.
        It looks like you have a short edge segment in the curve in your 2019 version that isn't there in the other one. How did you create that?
        • J
          jackg00
          Thank you for picking this up Dave.
          I did:
          150cm line on red
          75cm line from the center on green
          arc from ends of 150cm line pulled out to 75cm - 32 segments
          delete half the arc
          offset
          Loops start to appear after around 6.5cm on pro. The same process on Make and loops never appear.
          As far as I can see the first segment is in the same place on both files, new files attached.
          Make
          Pro
            Upload the actual SKP file that gives you problems.
            • J
              jackg00
              Thanks again.
              Attached is the Pro: Error and Make: No Error files
              Pro: Error
              Make: Correct
                What Pro version are you trialing? When I open the file called Corner Error it gives the message that it was created in SU2016.
                When I run Offset on your example on the left, it works just fine.
                Click on the picture if it doesn't animate.
                When I open your "correct" file, I get this.
                And Offset works fine there, too.
                Click
                • J
                  jackg00
                  You are exactly right.
                  I have downloaded the new version and all is fine. It seems it was a bug with the older version.
                  Thank you for your efforts.
                  • S
                    slbaumgartner
                    Just for the record, there were indeed bugs in the offset tool in previous versions of SketchUp. They are much improved in SketchUp 2019.
