    Animation help
    Scheduled Pinned Locked Moved Animator Beta
    renderpluginsextensions
    7 Posts 2 Posters 6.2k Views 2 Watching
    • GMthompsonG Offline
      GMthompson
      Good afternoon Gentlemen, and ladies
      i am having an issue getting a video to produce, i get the frames generated in a file generated from animator but not a video
      i am using SU 2019, i have FFMPEG installed in the plugins folder where libfredo6 is installed the ruby console is generating the following
      NATURAL image 66 time = 2.6000000000000014s Image66.png frame = 66 res = 1510x816
      NATURAL image 67 time = 2.6400000000000015s Image67.png frame = 67 res = 1510x816
      NATURAL image 68 time = 2.6800000000000015s Image68.png frame = 68 res = 1510x816
      NATURAL image 69 time = 2.7200000000000015s Image69.png frame = 69 res = 1510x816
      NATURAL image 70 time = 2.7600000000000016s Image70.png frame = 70 res = 1510x816
      NATURAL image 71 time = 2.8000000000000016s Image71.png frame = 71 res = 1510x816
      NATURAL image 72 time = 2.8400000000000016s Image72.png frame = 72 res = 1510x816
      NATURAL image 73 time = 2.8800000000000017s Image73.png frame = 73 res = 1510x816
      NATURAL image 74 time = 2.9200000000000017s Image74.png frame = 74 res = 1510x816
      NATURAL image 75 time = 2.9600000000000017s Image75.png frame = 75 res = 1510x816
      NATURAL image 76 time = 3.0000000000000018s Image76.png frame = 76 res = 1510x816
      NATURAL image 77 time = 3.040000000000002s Image77.png frame = 77 res = 1510x816
      NATURAL image 78 time = 3.080000000000002s Image78.png frame = 78 res = 1510x816
      NATURAL image 79 time = 3.120000000000002s Image79.png frame = 79 res = 1510x816
      NATURAL image 80 time = 3.13s Image80.png frame = 80 res = 1510x816
      Command FFmpeg for mp4 = "C:/Users/gmt/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ffmpeg.exe" -framerate 25 -i "Image%02d.png" -c:v libx264 -pix_fmt yuv420p -q:v 1 "Film 1.mp4" 2> FFmpeg_log_mp4.txt
      ===> Status FFmpeg for mp4 = false
      you can learn something everyday by paying attention
        GMthompson
        posting a snap of the video generation window
          GMthompson
          from this window the GUI button open folder does nothing, no idea if that is useful information
            GMthompson
            in my case 9 out of 10 times it is an I/O problem.......
            <----- I/O = idiot operator
            • fredo6F Offline
              fredo6
              Could you check that ALL images are generated correctly, ie, the complete sequence of images. This may be due to one or several missing images.
                GMthompson
                anim3.JPGyes sir 80 frames gets created, as long as the image sequence is selected/highlighted
                  GMthompson
                  the video would get generated in the same folder correct
