    Window Builder updated (v 1.1.0)
    12 Posts 9 Posters 25.9k Views 9 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      New release on the EW site today: http://extensions.sketchup.com/en/node/6841
      What's new in v 1.1.0:
      • Ability to save and load presets
      • Ability to preset custom layers for 7 parts of the window
      • Bar dialog fixed, (typo in the EN-US language file)
      • Fixed bug: loosing some values when configuring accessories (bar, shutter, etc)
      • Fixed bug: help button ineffective in the window by face dialog
      • Dialogs are now modal on PC and on Mac
      • Cosmetic graphics changes (homogeneous button sizes)
      • Replaced "Component name" with "Custom name" in the dialog
      • Donate button added
      • PDF Help file updated
      DB
      • N Offline
        nguyentuyen1986
        Hopefully this plugin becomes a paid version with many added doors & windows.
        • G Offline
          gameongrant
          Great plugin! Agreed, multiple configurations would be great. Also the ability to use custom sections would be brilliant. Keep up the great work Didier
            Didier Bur
            Hi all,
            The next release I'm working on will have the following changes:
            3 window types added: single opening, side-hung, australian
            New glazing type added: jalousie
            Click on the image for a short video
            Materials are now saved in presets
            Replaced "Sashes" with "Window leafs" in the dialog
            Fixed bug: loosing "snap to" and "cuts opening" values when using the eyedropper
            Fixed bug: wrong screen box drawing if screen opening percentage was zero.
            Fixed bug: wrong cover profile drawing when "Both" option was selected.
            New (experimental) interactive tool to open/close casements
            DB
              Rudhamstile
              Failed to install this extension in SU 2018.
              Have tried a new SU Repair install admin rights etc.
                What do you mean exactly by "failed to install"? How did you attempt to install it? What is telling you that the installation failed?
                • Y Offline
                  yovanygonzalez
                  I have a problem. I am trying to use the Windows Builder plug-in and, for some reason, when I tried to open the hole, the windows did not cross the wall, staying on the face. Any ideas?
                  Thanks in advances
                    Didier Bur
                    Hi Yovanygonzalez,
                    Could you please post a SKP including such a "stick-to-face" window ?
                    Thx
                    DB
                    • mark_in_seattleM Offline
                      mark_in_seattle
                      Looks like a very good and useful plugin. Unfortunately, myself and a few other MacOS users with SU-2021-pro are able to install the extension and use the settings window..etc, however clicking CREATE & PLACE does nothing, creates nothing on any layer..... bummer.
                      Anyone running SU-any-version under a MacOS able to create windows with this extension.
                      -- thank-you
                        Share your .skp file with us so we can see what you have set up.
                          allanpepito
                          I'm first timer. I love the SU and its plugins including Dib's window builder. I have a bit of an issue and hope someone can point out what I've done wrong here. I tried to use the window builder latest version 1.1.0 and noticed when I pressed the wall puncher the hole was created but not exactly on the spot where the window is located. The hole is horizontally fine but vertically lower by ~250mm. Note the wall had guide lines on it. If there are no guides on the wall it works perfectly. The problem only appears when guides are present in the wall. I need the guides for placing the window in the correct location.
                          Tried various tricks but failed to figure out what exactly is happening. Hope you can guide me as I'm beginner. Thanks in advance.
                          Here's the latest of my model with windows at the right spot that's because I created the hole first then added the window. However I added a sample window at the side of the house with the problem I was talking about. Thanks again for looking into this.
                            SUHEIRELALI
                            all a Mac user here, when I click create, nothing happens. its a shame looks like a great extension 😞
