    [REQUEST] Convert single instance components to groups
    5 Posts 3 Posters 1.8k Views 3 Watching
    • J
      jshal
      I was looking for quite while searching for the following problem:
      Importing (Revit) DWG data into Sketchup creates a lot of single instance components. The trouble is that when copying multiple of these files together that Sketchup slows down to a crawl because it is trying to match components that are similar. Usually I end up with sketchup files with hundreds of single component instances. Sketchup works faster when these single instances are in fact groups, making copying between sketchup files way faster. Normally I explode the selected instance and group these again, but with hundreds of these, this is too cumbersome.
      So what I need is the following:
      1. select all single instance components within my current SketchUp file (or current selection)
      2. convert these to standard groups
      I think this is quite useful for anybody working with imported files and want to keep on working quick.
      For number 2) I found the following code snippet from sdmitch (https://sketchucation.com/forums/viewtopic.php?f=323&t=17590&p=140679&hilit=single+instance+component#p623006)
      @mod = Sketchup.active_model
      @ent = @mod.active_entities
      @sel = @mod.selection
      @vue = @mod.active_view
      cmps = @sel.grep(Sketchup;;ComponentInstance)
      cmps.each{|ci|
       grp = @ent.add_group(ci)
       grp.name = ci.definition.name
       ci.explode
      @mod.definitions.purge_unused
      [highlight=#ffffbf:39rhwwt6]Does anybody know how to realize part 1?[/highlight:39rhwwt6]
      Thanks in advance!
      • TIGT
        It's relatively straightforward...
        Here's 1 AND 2 combined...
        This code finds all components that have just one instance and makes a new group in place of the instance, containing its contents, using the same name/layer/material as the instance itself.
        The now unused definitions are deleted.
        It is one step undo-able
        model=Sketchup.active_model
        defns=model.definitions
        model.start_operation("ci2gp",true)
        defns.each{|defn|
          next if defn.group?
          next if defn.image?
          next unless defn.instances.length==1
          inst=defn.instances[0]
          name=defn.name
          layr=inst.layer
          matl=inst.material
          ents=inst.parent.entities
          tran=inst.transformation
          grp=ents.add_group()
          gents=grp.entities
          i=gents.add_instance(defn, tran)
          inst.erase!
          i.explode
          grp.name=name
          grp.layer=layr
          grp.material=matl
        defns.purge_unused
        model.commit_operation
        • J
          jshal
          Wow, TIG, you have saved my day(s) πŸ˜„ Big thanks!
          • I
            iMacThere4iAm
            Sorry to dig up this old topic but your code above causes a bugsplat in Sketchup 2022. Any idea what could be the cause?
            • TIGT
              It's a snippet of old code but it should work OK.
              It works for me on a PC - I don't have a suitable MAC to hand...
              Nothing different in v2022 as far as I can see...
              What exactly are you trying to do, are there any Ruby Console messages before the failure ?
