    Parametric site modeling in SKP?
    7 Posts 4 Posters 1.5k Views 4 Watching
      coreiter
      I'm looking to see if there is some kind of parametric building/modeling massing plugin, etc for SKP. Ideally, say I'm doing multifamily, I can open a plugin, type how many stories the building is, select single loaded or double loaded corridor, and then by click and dragging a line out, building massing is generated with the correct floor heights, every time I drag out another 30' or so another unit is added (maybe this is just a rectangle) and if the line takes a corner the plugin would place a corner unit there. Obviously there are other features that would be helpful, but just wanted to ask and see if anyone has heard of anything like this? Thanks!
      • K Offline
        kaas
        maybe you can with the Viz plugin?
        https://www.fluidinteractive.com/products/sketchup-extensions/viz/
          coreiter
          THanks - i was going to look into that but I'm going to have to learn the program - didnt know if anything already existed.
          • JustinTSEJ Offline
            JustinTSE
            You might want to check out Modeleur -
            https://www.youtube.com/watch?v=UXCHJTxQR1s
            • it's an urban design extension that seems like it might line up with what you're looking for.
            • jujuJ Offline
              juju
              Aaah, if only Modelur was cheaper.
                JustinTSE
                It's definitely not targeted as a hobbyist extension πŸ˜„
                  coreiter
                  That's pretty much exactly what I was looking for! Yeah it's pretty but maybe worth it. Thanks.
