    Missing linework in 2D
    3 Posts 2 Posters 6.1k Views 2 Watching
    • utilerU
      utiler
      Hi guys, anyone notice this happening when viewed in top view?
      Attached is an example of the issue that appears when changing from perspective to 2D plan view. all linework is on the horizontal plan but for some reason when viewing in 2D the linework [and guides] disappear.... really annoying.
      linework missing.wmv
      Just Curious...
      • TIGT
        Do you have any faces on the ground-plane ?
        If you change the View to Hidden-Line [i.e. no faces], does it still happen ?
        If you change some of your OpenGL settings in Preferences does it improve ?
        • utilerU
          utiler
          Thanks for chiming, TIG
          Yes, the planes were on the ground plane; I never thought to check that!!! I guess I've always started generating line work on the ground plane and wasn't aware that even when hidden style is active, two or more planes won't display...
          I know what I'll do from now on; set my floor level above the GL.
          Easy fix. Thanks again. πŸ‘ πŸ‘
          Just Curious...
