    Problem with V-ray
    renderpluginsextensions
    8 Posts 2 Posters 5.7k Views 2 Watching
    • P
      port
      Every time I try to render I get this error in this model, I tried it with other models and it render fine.
      plz help me here! 😒 😒
      this is my problem!
        Did you try contacting the folks at Chaos Group?
        • P
          port
          I'm waiting for the answer
            The fact that this only occurs with this model suggests there's something wrong with the model. Perhaps some issue with textures.
            • P
              port
              I'm waiting for your answer
              • P
                port
                What do you think I can do to repair it?
                  Why are you waiting for my answer. You should be waiting for an answer from Chaos Group's technical support. You said you are waiting for an answer from them, right?
                  Short of getting a response from the Vray people, if I were you, I'd start investigating the the problem model. Remove custom textures and see if you can get the render to complete. Look at what works in your other models. Compare them to this one and see what is different.
                  • P
                    port
                    sorry, the message was repeated without the previous correction
                    thank you so much! I'm trying to clean the model as much as I can to see what happens
