ANIMATOR APPARITION AT 45
I am trying to figure out how to do an apparition cut at 45degrees for a cutaway. I had somehow stumbled upon it in my previous attempts, then decided to start it over with a fresh animation. I have not been able to recreate it in Animator.
I have the section planes set up in sketchup tabs working perfectly, I just dont understand how to get the 45 degree cut into my animation. Please help -
Currently the section planes are parallel to the axes of the object group or component.
So I guess you simply rotated the geometry content inside the object, so that you give the illusion that it is cut at an angle.I may develop an option to choose an arbitray plane for the section plane.
Fredo
Register LoginAdvertisement
