Fredo6 Animator update problem
Thanks for the quick reply! I did use Positioner to record the initial position of the whole structure, but as soon as I opened Animator the roof got up above again.
You can assign a positioner to a film.
Just double-click on the film name to get this dialog.
Animator stopped working and no longer loads into LOTTT? I've updated to the latest version 4.5a and also the current lib fiile. PErhaps it's a licensing issue as there has never been a paid version until now? if so how do I purchase that? cant seem to see that option on the sketchucation site
I need to understand more about "Animator stopped working".
Does Animator shows in the toolbars and in menu (Tool > Fredo6 Collection)?
If so, do you get a message when you start Animator? Open the Ruby console before launching Animator, in order to catch possible errors.
Could you post the output of the menu command Window > LibFredo6 Settings > Fredo6 Plugin Information for Sketchucation Support.
I got it working again with the latest Library, which was a later version than the animator plugin page linked to. Thanks for getting in touch.....keep up the good work, and glad to see you are charging money for your work.....finally!
Register LoginAdvertisement
