    Plugins
    extensions
    2 Posts 2 Posters 3.1k Views 2 Watching
    • P
      Pappy2019
      Fairly new to Sketchup. I installed Sketchup 15 about 3 weeks ago and just today (after reading a bit in Sketchup For Dummies) I saw 3 plugins it suggested I load before actually 3D printing some of my stuff. They were: Cleanup3, Solid Inspector and another file that is also needed TT_Lib2. Went through all the steps and each was supposedly downloaded and installed BUT.. the only one visible on the Sketchup screen is the Solid Inspector plugin. It's in the pulldown menu 'Tools' under Sandbox. Any help would be appreciated.
      Pop
        CleanUp should be in the Plugins or Extensions menu The name of the menu was changed from Plugins to Extensions later.
        TT_Lib is a bunch of common support files for a number of the author's extensions. You normally don't need to access them directly.
        Why are you using SketchUp 2015? Why not SketchUp 2017 Make?
